Hi all,
I'm here to ask a question abt my problem.
In short, I extracted only 1 part of all rar files of a video, just to check the quality.
But my MPC (I installed K-lite codec pack full v5.30) always ended up stopped working the moment I tried to open it.
It's strange because I used to be able to view that kind of incomplete video (older version,forgot what version) . Maybe the new version really cannot do it??
Anyone also got the same experience..care to share if you know one or two solutions?
Thanks a lot!
Try VLC media player.
It could be a codec issue, or the part of the video you're trying to view doesn't have the video's header (or complete file information).
Also, you might want to give MPCHC a try.If cameras add ten pounds, why would people want to eat them?
I think the pack I have installed is including that home cinema also, the same crash happened.
And it is not only a certain video.
I have tried many and none of them working.
And afterall it works in vlc.. so i guess nothing wrong in the video.
And hw abt you?? You using the same k-lite codec pack also?
I hv tried re-installed svrl times also.
Thanks for the suggestion anyway.
No, I generally don't recommend codec packs (with the possible exception of ffdshow, depending on whether or not you want to classify it as a codec pack).
MPCHC, like VLC, tends to default to its own internal filters, not those installed on the system, so if VLC works, MPCHC should work as well, in theory. However, MPC/HC also depends on Video for Windows/DirectShow codecs, so if something's broken, there...
I believe K-Lite also includes a 'tweak tool' that attempts to look at your installed codecs and see if anything's wrong with them (standalone version can be found here). I have no idea how well or if it works, but since you already have K-Lite installed, it might be worth a try. But only let it scan/troubleshoot - don't disable/enable codecs and filters unless you know what you're doing.
What error(s) do you get when MPC and/or MPCHC attempt to play the videos?If cameras add ten pounds, why would people want to eat them?
So you unpacked only a small part of the total archive - i.e. an incomplete part of a video - and wonder why you can play it properly ?
VLC works because it is built to play partially downloaded or damaged files, but most other players expect you to have the entire video, not just a chunk. You could have been missing anything - the index (and certainly part thereof) and other meta data required for playback.
I think darkw1zard is saying this happens with all videos, not just the partially-extracted one... but I'd want him to confirm that.
No video with Media Player Classic on Windows 7 Ultimate.
By Nagashi in forum Software PlayingReplies: 4Last Post: 23rd Jun 2010, 08:56 -
Video Quality for full screen on Media Player Classic?
By mimioreo in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2010, 18:33 -
Subtitles stopped showing in Media Player Classic
By pzoggy7 in forum SubtitleReplies: 3Last Post: 6th Jan 2010, 12:01 -
Bookmark a video in media player classic?
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2008, 22:02 -
video skips in media player classic.
By zzyzx2 in forum Software PlayingReplies: 6Last Post: 4th Oct 2007, 12:21
